6112 question
Family_Wagon
So I’ve read through the suspension threads and a bunch of builds in the process of planning for the next project and I’m pretty sure I’m going with Tundra 6112’s (still unsure on what springs as I’m currently stock weight, I’ll be adding bumpers, winch, skids, a rack…. All that fun stuff eventually but not sure how the ride will be if over spring in the meantime) Dobinsons 210’s and LC Tokicos in the rear. I’ve seen that through wheelers you can select your spring rate which once I decide will be nice, what I’m wondering is, is there a better deal on them somewhere or is wheelers the way to go?
Thanks in advance, I greatly appreciate all the thorough write ups and part numbers. This is probably the most informative forum I’ve been on.
I think wheeler's is the only place I've seen that allows you to choose a different spring than what the tundra 6112's are designed with (700 lb/in spring rate).
bobdjr41
