'87 Engine Light Code Help !?!?!
elcidsurfer
So ever since I got my '87 T4R the check engine light comes on once I get to a cruzin speed. Doesnt matter how fast Im going just as long as Im cruzin at a constant speed then it goes away when I change speed.
Anyway, tried the paper clip trick on the diagnostic input and got the code: 5 flashes - pause - 6 flashes - pause - 11 flashes. Then it repeats. Anyone know what this code is?
THANKS!!!
THANKS!!!
not sure of the code flash but, it sounds like o2 sensor to me.
sorry bringing this thread back up, i put a 50 state legal lcengineering header on my truck and since then I've been getting the same symptoms as listed above, I replaced the o2 sensor, but that didnt fix it, so I replaced it with the universal heated o2 sensor they recommended. still no fix. I have noticed the light wont come on until its warmed up (its a code 5- o2 sensor/ecu, I plugged in a different ecu but that didnt fix it either). i'd put the old manifold back on but I threw it out. Im a month expired registration and need this fixed. Anyway this could be another problem thats throwing this code?
thanks
I also apologize for posting in an older thread, but that pause in between sequences indicates it show 2 codes. Code 5 and Code 6.
I am sure an o2 will fix your problem though =)
