87 sr5 build
It has been a while since I have posted an update. I just finished up building on my front bumper. I started with a trail gear winch and built off of that. I have a warn xd9000i that I will be installing.
I also started to do some sanding and priming to prep for paint. I hope to have it ready to go to the body shop to be painted by september
Made some more progress on the sanding and preping for paint. Hope to have it prepped, primed and ready for paint next week
FINALLY!! I got it back from the body shop with the rust fixed and a fresh coat of corsa blue paint. it will still be a couple of days on the top. It will be a semi gloss black.
Beautiful. I see you did all the prep. What level did you get it down to? 200 grit? 400 grit? Is it two stage paint or single? You have to replace your avatar when you get it all together.
Looking good, my plans are for the exact same stance. I've got the chevy's and the spring hanger kit and the BJ spacers. Still looking to pick up fresh shocks and a set of 33x10.5s.
P.S. Were you able to put any miles on the 33s prior to swapping in the 4.88 gears? How'd the yota run with the 33s on stock gearing? Assuming they are 10.5s and not 12.5s.
