884 ome coils installed does this look correct?
ohnoitsthecops
well i mounted the 884 coils to my edelbrock shocks and they dont seem to be sitting right. or maybe its just me? in the picture you can see how its closer to one side. is this because theirs no weight on it?
don't want to find out the hard :lol:
They do look a little weird can you upload a pic of the whole thing?
They're fine.
Mount that ish up man!
Zstampe are you running uca? Trying to decide if I should wait
What tires and size are you planning on running? Are you or will you plan on using wheel spacers or aftermarket wheels?
I'm at about 3.5" up front with "skinnier" 285's and wheel spacers with OEM uca's and havent had any problems! My alignment is back to factory spec's and it handles great. I would install the lift and see what your alignment numbers are and if you rub the uca's. If you need em, buy em!
The reason they look like that is the spring is not Wieghted ... Meaning no vehicle static wgt. "preload" Once mounted they will have a slight load and compress and all will be happy !
Cool I am torn I have 1.5 wheel spacers, but I'd rather get rims with the right offset. And I plan to run 265/70/17 since I can't justify the 285 on my patrol vehicle. I guess I'll go stock uca and if it's no good I'll get the spc uca
Just finished lifting my fj so the 4runner is up next :cry:<--- my wallet
ohnoitsthecops, it's so hard to resist after reading mods and how there truck look to nice and not to pull your wallet out.
BillM777
