891's and Tundra coils?
highside74
I have a set of 891's for my 99 limited that I was going to match up with a set of 4 KYB Monomax shocks that I have ready to install and a pair of Tundra coils that I haven't bought yet. My question is will this sit pretty even or will there be much rake? A little would be okay. Thanks.
I'm not sure it'll be an inch, it depends on if you have weight back there to sag the 891s a little. If not, they give ~3.5" and the Tundras will give ~2-2.5" or so. I don't think the rake would be bad if you have ~200lbs. of stuff in the back. Otherwise, you could do spacers or go with adjustable struts in the front.
Loved it. The TRDs ride great and flex great. The 891s carry weight well. I had 890s before them and didn't feel much difference in the ride. Later I added a topout spacer to the front and 10mm packers to the rear. I have since changed to ToyTec Coilovers in front, I was trying to figure a way to use the TRDs with coilover adjusters. Couldn't be done, they are not long enough. I also have some LC 9.25 wraps for the rear (not installed yet, they have to wait a few weeks till I get back from the Marines).
The problem is, lack of height. I keep wanting more.
I have this exact set-up. I love it. I even ride with my 891's unloaded most of the time and don't mind it one bit. Im sitting at about 1" rake even with the tundras and a 3/8" top plate spacer.
I pretty much will be unloaded unless it's hunting season. So I guess I will get 1/2" spacer's for the front and should be with in 1/4"-1/2" of even. Thanks for the info.
44runah
