90k Service
alms_lefko
So, I searched... but could not find any specific information (every thread seemed to have different advice).
The (new to me - 5k miles) 4 runner (05 v6 - 4WD - Sport Edition) just hit 90k miles.
A list of what I was thinking (and some questions):
-oil
-air filter
-cabin filter
-regrease drivetrain with Mobil 1 synthetic lube
-spark plugs (what are the NGK OEM part numbers)?
Other things I was 'thinking' and curious your advice:
-transmission filter/fluid (drop pan)
-differential fluids
-brake fluid
Anything else I'm missing? TIA!
<table border="0" cellpadding="0" cellspacing="0" width="258"><colgroup><col style="mso-width-source:userset;mso-width-alt:7094;width:146pt" width="194"> <col style="width:48pt" width="64"> </colgroup><tbody><tr style="height:15.0pt" height="20"> <td style="height:15.0pt;width:146pt" height="20" width="194">Maintenance Items </td> <td class="xl63" style="width:48pt" align="right" width="64">90,000</td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Air Filter Element </td> <td>Replace </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Ball Joint </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Brake Hose/Line </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Cabin Air Filter / Purifier </td> <td>Replace </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Condenser HVAC </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Constant Velocity Joint Boot </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Coolant </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Disc Brake System </td> <td>Diagnose/Test </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Drive Belt </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Drive/Propeller Shaft </td> <td>Lubricate </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Drum Brake System </td> <td>Diagnose/Test </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Engine Oil </td> <td>Replace </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Evaporative Emission Control Canister </td> <td> </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Evaporative Emissions Hose </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Exhaust System </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Fluid - A/T </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Fluid - Differential </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Fluid - Transfer Case </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Fuel Filler Cap </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Fuel Supply Line </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Fuel Tank Mounting Straps </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Oil Change Reminder Lamp </td> <td>Reset </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Oil Filter, Engine </td> <td>Replace </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Radiator </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Spark Plug </td> <td> </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Steering </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Steering Gear </td> <td>Inspect </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Timing Belt </td> <td>Replace </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Tires </td> <td>Rotate </td> </tr> <tr style="height:15.0pt" height="20"> <td style="height:15.0pt" height="20">Valve Clearance </td> <td> </td> </tr> </tbody></table>
