93 motor swap
i had the same ac bracket problem sorry forgot about it in the pm
No problem I should have changed it I did measure the bracket and it is the same size but the mount holes are 1/2" off from each other and I think I have a blockage in my TX valve I hooked the Gage's up to night high side is right psi but the low is pulling vac so I get I have a fun day tomorrow taking apart the dash to do this tx valve
can I ask, where did you get the motor and how much does it cost?
Jdm engine zone call them direct and they will cut you a mice deal is was 1100 shipped to my door. The mileage seam to be very low. If I would have rebuilt the old motor I would have 1000 bucks just in head work and block work at the machine shop. The guy said it would be 700 bucks just for the heads and 3 angle valve job plus 300 just to deck the block plus if the mains need work that would have been more. For what it takes to replace a Motor I have 9 hours in it. I think if I ever did have to do a head gasket I would just order another motor.
Well here she is all cleaned up and new tires and all.
looking good, thanks for the information I appreciate it.
No problem next step is to get some new springs for the back thinking about the OME 900 don't really want a lift just get the sag gone someone said the 900 where a good replacement with out lifting but still looking for pics and stuff on them right now . Plus I have to do the front brakes tomorrow if the rain would ever stop.
alsayner
