95 4runner 4x4 93k miles
aixgelo78
95 4runner 4x4 93k miles V6
hey guys/gals...
I have my 4runner for sale. I need a truck that can tow something heavier, thus my truck is for sale. I preffer a local sale and cash transactions, If you are from out of state, I will help you as much as I can. Please feel free to give me a call, but please dont waste my time and yours
under 93k miles
V6
about as mint as they come
no surprises
no accidents
its gold with tan cloth interior
original mats in mint condition
automatic 4x4
power sunroof
power locks
cruise
freaking cold AC
front brush guard
power antenna works perfectly
good stuff:
before I purchased the truck:
nov 05:
ALL cooling hoses were replaced
new outer tie rod ends
new cv boots
the following maintenance done at 91.5k miles
head gasket
valve seals
valve cover gasket
exhaust manifold gaskets
upper intake manifold gasket
lower intake manifold gasket
cleaned intake manifold
cam seals
egr gaskets
cold plugs
timing belt
thermostat
water pump
radiator
cleaned full cooling system
synthetic oil change
when heads were out, my mechanic told me that the cylinders were nice and tight, and no scores on the cylinder walls
new wipers
brand new spare
at 92k miles
new dynoflo exhaust (very quiet)
performance intake
new egs filter
spark plugs
cap
rotor
new front disc
new front pads
radiator cap
4 wheel alignment
4 wheel balancing
at 92,344 as of 8/20/06
lubed all driveshaft joints
deatailed interior
cleaned exterior
tranny fluid is nice and clean
near future (have the parts already)
flush tranny fluid
flush rear diff
flush transfer case
replace fuel filter
replace pcv
the bad:
I have a quarter size rust mark on the rear bumper that I covered with a sticker =) you can purchase a new one for about $100 if it bothers you
I have gotten 19.06 mpg straight highway with 3 poeple in the car to and from MD with tires at 40psi(cold), and 15.1 city driving...not bad for a tank, I want to break 20mpg with a little more air in the tires and after I change the drivetrain fluids.
I might be forgetting some stuff here and there...so if you are interested please give me a call. This truck has never been used to tow, nor was it used offroading. I should have most receipts of the work, it will be obvious anyway. Also I have most parts that I removed.
$6000 b/o
chris
732-801-5109
[email protected]
located in central nj
As you guys can tell, there is something wrong with me=), I like to do everthing at once. I like this truck a lot and I was in a mission to get the most mpg out of it, but I need a tow vehecle.
