95 4runner no start.
wreckerman
I've recently bought a 95 4runner with 3.0 v6, automatic transmission, and 4wd. I bought it off my uncle he told me it started about 2 months ago and all it'll do for me is crank. I've change plugs, wires, distributor cap, rotor button, coil, igniter, 80a fuse, head relay and starter solenoid relay. It'll crank but no spark at all. I've shot starting fluid straight to the throttle body and it didn't even speed up the motor and I've pulled the distributor/coil wire cranked and no arc off of it either I'm at a loss any advice you have will be helpful thank you
Check the maf and be sure it's not shorted. Had one do that. Check to be sure that the pick up coil in the distributor is good
I'm having a very similar problem with my '89 4 cylinder. It stalled one day and will crank but not start. I've replaced the plugs, coil/igniter assembly, checked timing belt, replaced the ECU and nothing has made a change. The coil delivers spark, fuel flows just no ignition. Thoughts and/or advice would be greatly appreciated.
DJNutshell
