'96 4runner diesel?
shoes
I know my new used SR5 '96 4runner isn't a diesel, but I am wondering where they hid the ignition system. I've done a lot of shade tree mechanical work over the last 35 years: brakes, exhaust, oil changes, plugs, points, cap coil, radiators, alternators, manifold gaskets etc, but I can't find the spark plugs, coil, dist cap and coil on this truck. It has the 6 cyl engine. Where is all this stuff hiding?
And a related question: which repair manual is better...Chilton or Haynes?
your truck has ignition coils they are the six modeules that screw on- top of the cylinders. when you un-bolt the ignition coil it has a boot on it that runs down into the cylinderthat sends fire to the spark plug these modeules take the place of a dist. cap your truck does not have a dist. cap to answer ? I hope I helped ya out.
Yeah, your truck does not have a distributor system. It uses a "waste-spark" system. Your ignition system basically consists of 3 coil packs on the left side of the engine on the valve cover.
Manuals
Get a Chilton. Haynes usually leans towards European readers/models, though they do refer to US models.
This is the coil pack your looking for.
pliers_disconnect.jpg~original
Attached to this is the plug wire that goes to the other side of the block. Under this is a spark plug. Just unbolt it and it pulls right out. Easy money.
