97 Limited 4x4 Body Parting Out
1986Runner
97 Limited 4x4 Parts
Updated: 9/5/12
I only have the parts listed below
I have some parts from a 97 Toyota 4Runner Limited 4x4 for sale. Most will interchange with 1996-2002 4Runners. All I have is what is listed. Pickup on the larger items, or can ship on your dime. I am near Santa Rosa, CA (North Bay). I only have what is listed. Some of these parts also work on the Tacoma.
I do NOT have any engine/trans/transfer case, doors, dash, seats, console, fenders, hood, bumpers, etc. If it's not in the pictures, it's unfortunately not available.
Drivetrain/Suspension/Frame/Underhood:
Control arms. Driver's upper and lower. $15/each
https://picasaweb.google.com/lh/photo/TeBhoaidmBqNMFOXUN1rmMfbDTgAOMqGUmthqgdHSTk?feat=directlink
https://picasaweb.google.com/lh/photo/-PeN2Lz8hcP00Dja9xqtfsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Ball joint - lower. Driver’s. Good shape. Perfect for a trail spare. $10
https://picasaweb.google.com/lh/photo/P7vUb3kLXe4SvlADaUucnsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Sway bar, front, no brackets/bushings. $20
https://picasaweb.google.com/lh/photo/vMNEIN4dwarwcjdEUEcHhsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Heater valve $10
IMG_4984 | Flickr - Photo Sharing!
Hood release cable. $5
https://picasaweb.google.com/lh/photo/5be3JlZomW6uKp3Z-D_LycfbDTgAOMqGUmthqgdHSTk?feat=directlink
Exhaust heat shields. V6. $5/each.
https://picasaweb.google.com/lh/photo/axJUP9kIkA1_B0Ufpmu08sfbDTgAOMqGUmthqgdHSTk?feat=directlink
https://picasaweb.google.com/lh/photo/w-ctA6p7TW5cSTfJgqWoYMfbDTgAOMqGUmthqgdHSTk?feat=directlink
Bump stops. Rear end, frame. $5 each.
https://picasaweb.google.com/lh/photo/Pkn58gAjH9r4RpLsPdoOHcfbDTgAOMqGUmthqgdHSTk?feat=directlink
Splash shield. Passenger inner fender behind A arms. $2
https://picasaweb.google.com/lh/photo/qxImsqfY3xtfNN_dmyItEcfbDTgAOMqGUmthqgdHSTk?feat=directlink
Splash shield. Driver inner fender in front of A arms. One hole ripped. $2
https://picasaweb.google.com/lh/photo/i8RXBDFQ85A3Q_1sovRIX8fbDTgAOMqGUmthqgdHSTk?feat=directlink
https://picasaweb.google.com/lh/photo/2buGL8wQhaoWD1hlgjTVKMfbDTgAOMqGUmthqgdHSTk?feat=directlink
Interior:
Emergency brake handle, $5
https://picasaweb.google.com/lh/photo/fMM6msaB4_BCKfGTS09sTsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Steering column with ignition switch & key, $30
IMG_4974 | Flickr - Photo Sharing!
Heater & a/c box, $40 all. No fan
IMG_4989 | Flickr - Photo Sharing!
Sliding glass sunroof assembly in nice shape with sliding cover & drain tubes. Oak in color. No motor. $50
https://lh3.googleusercontent.com/-R27-9b-ITRs/Tzlqtjnr2GI/AAAAAAAAAGY/yrFzAIj3gU8/s640/IMG_5086.JPG
https://lh5.googleusercontent.com/-Y-Q1BEMzJ3g/TzlqvaROPWI/AAAAAAAAAGg/98U_7aWPGRQ/s640/IMG_5085.JPG
Passenger rear seat area trim panel, $10.
Rear cargo floor trim, $10.
IMG_5008 | Flickr - Photo Sharing!
Rear cargo compartment side panels (nice shape), $20/each
IMG_5006 | Flickr - Photo Sharing!
IMG_5005 | Flickr - Photo Sharing!
Front A pillar trim. $10/each
IMG_4977 | Flickr - Photo Sharing!
Front A pillar grab handles (by windshield - NOT the roof mounted ones above the doors) Oak. I have three screw covers, and am looking for the 4th. No screws. $5/each
https://lh4.googleusercontent.com/-ewmGSLgmLDc/TzlqgmhsyrI/AAAAAAAAAF4/_EQ73Zwk7cE/s640/IMG_5081.JPG
Passenger's B pillar trim. $10
IMG_4998 | Flickr - Photo Sharing!
Cargo cover brackets. $5/both
IMG_4992 | Flickr - Photo Sharing!
Weather strip. Rear doors body side, great shape. $15/side.
https://picasaweb.google.com/lh/photo/uSMc-GYqxUvdzkjXy3Ul7sfbDTgAOMqGUmthqgdHSTk?feat=directlink
https://picasaweb.google.com/lh/photo/iRe0-_TfglUhHAR08nBCvsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Steering column to rack driveshaft/u joint assembly. $20
IMG_5002 | Flickr - Photo Sharing!
Steering shaft floor collar. $5
https://picasaweb.google.com/lh/photo/0IdNI1U5OBByJ_JZIUna1sfbDTgAOMqGUmthqgdHSTk?feat=directlink
Rear seat back hinges, $10 all
https://picasaweb.google.com/lh/photo/MqfQn89lwj-jewTz4pwNPsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Gas pedal assembly/cable. V6/Auto/4x4. $10
https://picasaweb.google.com/lh/photo/Vibj28iA362yGZp6Buk8MsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Dash brackets - radio area. $5 both.
https://picasaweb.google.com/lh/photo/CBKtzsZDpIDgqALSrph0DsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Cargo area undercarpet rubber mat. $5
https://picasaweb.google.com/lh/photo/J5VGJS3TarE8EBKfUo_dxcfbDTgAOMqGUmthqgdHSTk?feat=directlink
Jack area mat. $1
https://picasaweb.google.com/lh/photo/mqAxwPF9nSE9R_cxWtymvMfbDTgAOMqGUmthqgdHSTk?feat=directlink
Firewall insulation. $20
https://picasaweb.google.com/lh/photo/vF5k_dmzsHRWFZuG1zTxA8fbDTgAOMqGUmthqgdHSTk?feat=directlink
Rear seat back latch strikers. $5/both
https://picasaweb.google.com/lh/photo/yxCOgSx_cA99gsqdMUAE28fbDTgAOMqGUmthqgdHSTk?feat=directlink
Seat belt height slider mechanisms (front). $3/each.
https://picasaweb.google.com/lh/photo/VO-rOXM7AjHqc3ODNER_5MfbDTgAOMqGUmthqgdHSTk?feat=directlink
Dash support. $10
https://picasaweb.google.com/lh/photo/_LKLkJitHxsgZm1al8jpBMfbDTgAOMqGUmthqgdHSTk?feat=directlink
Fuel tank wiring floor cover plate. $2
https://picasaweb.google.com/lh/photo/oA5D9hHkasqQomJaAAu9DsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Exterior/Body:
Rear taillight harnesses. $10 each.
IMG_5032 | Flickr - Photo Sharing!
Door hinges, $5/door (no driver’s front)
https://picasaweb.google.com/lh/photo/kqUFUaoSHrR237uFss4YmsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Hatch hinges, $5/both
https://picasaweb.google.com/lh/photo/ck83mHVDgw7IVc3pVzy55sfbDTgAOMqGUmthqgdHSTk?feat=directlink
Door latch strikers. $2 each.
https://picasaweb.google.com/lh/photo/GHEAl5EyY2pRJgYeQK-AFMfbDTgAOMqGUmthqgdHSTk?feat=directlink
Rear hatch latch plate. $5
https://picasaweb.google.com/lh/photo/Vg1BsQa8e5KbRHRCA5sTMsfbDTgAOMqGUmthqgdHSTk?feat=directlink
Rear hatch rubber bumpers. $2 each.
https://picasaweb.google.com/lh/photo/tKVY53_LFSK2LohMmiSv5cfbDTgAOMqGUmthqgdHSTk?feat=directlink
Limited Rocker Panel Trim brackets. $10 all.
https://picasaweb.google.com/lh/photo/NmeNLUD2LHe_hqJGyQjtjMfbDTgAOMqGUmthqgdHSTk?feat=directlink
Cowl panel. Some small dings. $15
https://picasaweb.google.com/lh/photo/kfz1X3BvN2vW9PGm9I63z8fbDTgAOMqGUmthqgdHSTk?feat=directlink
https://picasaweb.google.com/lh/photo/Cn7yfOlND7Q6w5vZdu8vpsfbDTgAOMqGUmthqgdHSTk?feat=directlink
https://picasaweb.google.com/lh/photo/1Bz9-ZOn4jSaWnTBdt141cfbDTgAOMqGUmthqgdHSTk?feat=directlink
Cowl to hood weatherstrip. Nice shape. $7
https://picasaweb.google.com/lh/photo/NXHxUtV4eLonGcRx8hToscfbDTgAOMqGUmthqgdHSTk?feat=directlink
Windshield wiper arm. With nut cover. $5
https://picasaweb.google.com/lh/photo/ojwzvjNs7dyGP0szcCiUs8fbDTgAOMqGUmthqgdHSTk?feat=directlink
Gas door release mechanism. Works good. $3
https://picasaweb.google.com/lh/photo/FzfIT1w2auBTgVtdasbc6cfbDTgAOMqGUmthqgdHSTk?feat=directlink
Gas lid cable. Works smooth. $5
https://picasaweb.google.com/lh/photo/kXT0rvHugKfJWbAxbdbtc8fbDTgAOMqGUmthqgdHSTk?feat=directlink
Gas door. White/Nice. Nice paint. $15
https://picasaweb.google.com/lh/photo/zcy-msFNPg4uKWTr8HCU4cfbDTgAOMqGUmthqgdHSTk?feat=directlink
https://picasaweb.google.com/lh/photo/LMReiCGFNZLo7ZR6Jfkpc8fbDTgAOMqGUmthqgdHSTk?feat=directlink
Body plugs. $0.50 each.
https://picasaweb.google.com/lh/photo/RhU7lmlD7gvwtOpbfPgIIcfbDTgAOMqGUmthqgdHSTk?feat=directlink
Fuel System:
Gas filler tube shield $5
IMG_4981 | Flickr - Photo Sharing!
Gas tank filler tube with fuel cap. Metal and rubber tubes. Vent line cut where it meets the tank, but can easily be replaced with standard fuel hose from auto parts store. $40
https://picasaweb.google.com/lh/photo/QQoSLEvDbJer9NO4-oarD8fbDTgAOMqGUmthqgdHSTk?feat=directlink
Gas tank strap. $5
https://picasaweb.google.com/lh/photo/admfTdadvR72hmMLpK8cUMfbDTgAOMqGUmthqgdHSTk?feat=directlink
Again, I am in Sebastopol (North Bay) near Santa Rosa, CA. The big items will need to be picked up or some other arrangement. I will ship the other stuff on your dime. Thanks! PM me your needs and I will get back to you. I want this stuff out of here! Make me an offer!
how much for the cargo area carpet shipped to 90808 CA ? and do you have the rear seat hinge covers? and is the dash available? and dash cup holder?
I have a local person supposed to come look at the carpet. If that falls through, you're first in line.
Unfortunately, I don't have the rear seat hinge covers, dash, or cup holders. If it's not listed, it's gone already. :(
Thanks!
do you still have the brake master cylinder? I'm located in Berkeley, can meet today. you didnt show any exterior parts, but just wanted to ask if any of that was available?
Yes, I do still have the master, however I am out of town this weekend, so I can't meet today. I can do another time or ship it. PM me if still interested.
I do not have any exterior body parts left. Thanks!
Let me know which ones specifically. I have an interested party on the passenger's side back panel right now, but I'll let you know if that falls through. Those rear panels are so large, that it would probably be somewhat expensive to ship. PM me with the exact pieces you want and if you can pick up or what zip you want things shipped to so I can get a quote.
Thanks!
Do u have the intake piece needed for the snorkel? The one one the top right of the picture...
Step15.jpg~original
Jesse1
