Hello everyone, I have a weird starting issue on my 97 4runner limited. When I go to start it after it has been sitting overnight, it cranks 5-6 times before it turns over. This issue only happens when the outside temperature is warm, If its cold outside it will crank 2 times and start right up or if its has be run recently it will start fine. I have replaced the fuel pump, fuel filter, cleaned the IAC, throttle body and MAF, replaced the spark plugs and air filter. I have ran a OBDII scanner on it also and its not throwing any codes. Any ideas?
