'97 LTD... Newbie needs help!
Tee-Bruce
Just bought (last Wed) a '97 Limited 2wd, 6cyl 160k....
1) The power locks are freaking out... cycling into the locked position numerous times while driving! Any ideas?
Are they supposed to lock automatically at a certain speed?
Thanx in advance!
Tony
Does it have the extra cost security system (VIP-RS3000)? If so, it may be having a glitch.
My son's has it and the doors lock when the vehicle is started. I believe it can be programmed to engage the locks in different ways.
i have no idea....there was no remote sold with the vehicle...I don't know that ther ever was one. How would I know if this security system is installed?
If you have one then one your centre console by the armrest will have a clip-in piece that has RS 3000 on it and a microphone thingy. It may also be on your dash. Easiest way though is under the drivers seat if there is a black box that's the alarm system. If there's a box under there you have it.
If there's nuthin under the seat then it may have an aftermarket system that is having problems. Only thing I would recommend is having a stereo stop check it out. Maybe you want to add an alarm or remote start when you do this they can probably fix the issue at the same time.
MMJR_T4R
