97 PreRunner Build 2wd!
ridetime88
5 months ago I purchased a 97 4runner Limited 2wd form a guy on Craigslist. It had 285,XXX on the dash and a stamp on the title that said, "For Mexico Export OnLy"... I was nervous about both of those things but i was told that it had a new motor put in that on my had 34,XXX on it. There was no paper work proving it, just the previous owners word.
The truck ran amazing and it was flawless mechanically. It had a flat rear tire and need valve cover gaskets and some TLC. He was asking $2400 but I got it for $1800 cash after explaining I was concerned about it passing smog, if it was registerable and all the things it needed. I knew it was a good truck and I would have paid the full price once I seen the title and it had Toyota of chula vista printed as the original owner. I bought it.
I knew I had a great truck since it ran so good but was skeptical about the claims of the work that hand been done. I was going to learn how true they were once I went to smog it.
It passed with low numbers!! The technician had mentioned to me he had never seen a truck with such high milage pass with such clean numbers. I was very happy. Went to DMV and they didn't even bat a eye at the stamp mentioning mexico and promptly issued me my new 2015 sticker. :cool:
So I then set my sights on what to do with this wonderful specimen. I started by removing the stock running boards, and trimming the rear mud flaps a bit. It came with 285/75/r16's that were baldy worn down and were rubbing on the front fenders at full lock. So I hunted down some BFG 265/75/r16 tires at local junkyard area tire shops near Brown field here in San Diego. There are deals to be had just got to look. I paid $50-$60 a piece for my tires each and had them mounted and balanced for an extra $10. It took 2 weeks to get all four tires, hunting for best tread. I put new front brake pads on, checked rotor run out were still good so got them turned.
This picture shows the old 285's and my Hellas I added.
Went out to ocotillo with the crappy tires and stock suspension with the Hellas. I knew for sure I wanted to build this truck. I built my neighbors 97, and wanted to join the club. I put ICON 2.5 front shocks, TC upper a arm with 1 1/2" uniball up front. I installed OmE 890 coils in the rear with double bypass rear 2.5 ICONS. I knew I wanted a truck the ride like his but I was looking for a different feel. More compression and rebound valving.
I did my oil, air filter a coolant flush, new thermostat, hoses to start. Completely degreased the engine bay, and began to start finding leaks specifically oil.
As I continued to assess the vehicles overall condition I noticed good things. No rust. No real damage. This chassis doesn't look like a 250 thousand mile truck. Looks as if it was garaged.
I ended up replacing my headlights with ultra star $59 bulbs and adding all new corner and tail lights. While I was at it I stopped by ORW and got a light bar on sale for $90. It has (3) 10watt CREE LED's that draws only 30watts and puts out 2,700 lumens! I had to make my own wiring kit to get it running. Just copied the Hellas style. Purchased a relay, relay wiring harness, in line fuse, and lighted switch. Everything was crimped and heat shrink tube wrapped. Came out great!
patnewton
