97 SR5 New Springs/Suspension
dml619
Looking for input, help on F/R replacement springs for my 97. I know you guys have a lot of threads on springs and shocks but looking for more detail if possible. Just installed new Bilsteins and it still rides and handles like a %$it. You guys talk a lot about ride hieght but no shock valving or spring rates Looking for a much tighter ride overall with minimal ride increase. Sway Bars ? Bushings?
Scroll through the last 5 pages and that you get you going in the right direction.
If you want a tighter feel to the 4runner, new springs, ball joints, and tie rod ends are a good place to start.
if you want better handling then get some sway bars.
major increase in handling and minimizes body roll. doing the bushings same time will be beneficial as well.
although going with the full set as in front and rear you will lose some flex in the rear.
not to bad in the front but the rear will lose quite a bit. if you dont mind then go with those.. the brand is called addco sway bars.
Thanks, Very familar with all the suspension companys. I owned one myself . I was looking for the best set up based on experience? Anyone else?
Ambrose67
