98 3.4 Supercharged Knock Codes
AZSportRunner
Junior Member
Hey everyone, let me start off with saying that I'm not new to 3rd gen runners as I've owned an 02 Sport 4x4 for almost 4 years and the truck has been great up until the A340F in it finally gave up at 260k miles.
Since it died I've been entertaining the idea of getting a 5spd runner like I originally wanted when I initially purchased my truck.
I couldn't believe that I found a 98 3.4 5spd 4x4 elocked with the 2nd gen supercharger at 270k miles after only looking for a few short days, after test driving the truck I came to the conclusion that the truck was well cared for mechanically but the owner did report that it would sometimes throw codes, P0325 and P0330 I believe, he said that this had gone away for a while but came back after he removed the 7th injector kit and the smaller pulley....
From what I've gathered the code is related directly to the sensors / harness more so than the actual detection of a knock. The motor ran very smoothly and the supercharger didn't rattle much at all at idle which to me helped confirm indicated the PO had rebuilt it when putting it on the truck about a year ago.
All in all the truck drove very well although the code was not being thrown when I last drove the truck as it still had the 7th injector / smaller pulley on it.
I guess my question is at 5500 bucks is that this seems like a good buy for the money even with replacing the sensors/ harness so should I be weary of the codes or still go for it? :help:
Sorry if this is all over the place as I'm out the door to head to work. If there are any more factors that would help an opinion along just ask.
Thanks in advance 3.4 gurus :heh:
Fyi
I forgot to mention that I'm going to look at the truck again tomorrow so if there's anything I should look for related to the supercharger etc. please let me know :doh: :thanks:
Codes have to do with the sensor circuit malfunctioning, not the engine.
Four hours tops to replace both sensors (ONLY OEM!!!!!!), manifold gasket, and sub-harness assembly.
It's all part of maintaining these rigs. They go bad.
Find out how many miles are on the SC. If it's more than 100K you're probably looking at a new nose cone in the very near future. They use to run around $275 but I believe they're up around $500 now.
Approximately 30k or so since he says he rebuilt it... I'm going to ask for all the receipts tomorrow to be sure.
I've read about people switching to GM knock sensors, to me putting GM electronics on a Toyota or anything for that matter sounds heinous but is there any weight to the idea?
Personally, I wouldn't replace the OEM sensors with anything but OEM. They'll probably last you another 250K or more. DO NOT go aftermarket on Knock Sensors.
Since you've owned an 02' before then you know about the radiator and LBJ's, UCA, LCA, Steering Rack bushings, I/O tie rod ends etc.
To me I consider that standard maintenance so if these haven't been done, you have some wiggle room for negotiation.
Holy Sh*t !!! I just looked at the price of a new nose cone. Damn, talk about jacking up the prices! Highway robbery. Magnuson must be part of the pharmaceutical companies.$751
3.4 4TH Gen Nose Cone Kit PTR29-35042
EDIT: Oversight on my part. You're looking at a manual. No milkshake worries.
2001ATL
