98 3rd Gen 2.7 P0420 code now P0401
mortreport
I've been working on chasing a P0420 code. Replaced PCV, gas cap and upstream O2 sensor. Reset code, drove it and almost immediately the P0401 came on. I have already replaced all vacuum lines. Is there something I did that could cause this code. I find it hard to believe that something suddenly goes bad minutes after installing new O2 sensor. Ideas or thoughts on this one? Thanks for any help.
This issue was fixed from dealer
Here is the solution
Description: EXHAUST GAS CIRCULATION FLOW EXCESSIVE DETECTED //// TECH FOUND FAULTY MODULATOR VSV AND CLOGGED PARTS , TECH RECOMMEND TO REPLACE EGR MODULE AND VSV, AND EGR TUBE CLEANING
PART # QTY
VALVE ASSY, VACUUM S 2586075060 1
VALVE ASSY, E.G.R VA 2587075030 1
GASKET, THROTTLE BODY 2227175020 1 , also clean throttle body
POSITION Sensor 89452-35020 1
NO AFTER MARKET PARTS OR ELSE IT WILL COME BACK.
Requires Cleaning on those places.
Toyota dealer price of service $700 USD or by your self just buy these parts
__________________________________________________ ______________
That EGR system uses a temperature sensor to detect flow, your either have a EGR valve that is stuck open, or a clogged catalytic converter raising EGR temps and reading it as excessive flow. Many young toyota techs are blindly throwing parts at older toyota's with EGR systems because they have no clue how they work.
Thanks much. If the EGR was stuck open, would it still run while idling?
If the EGR was stuck open the car would run very poorly, if at all. Possibly same symptom if the catalytic converter was clogged bad enough. most popular check of a clogged catalytic converter is to remove the upstream O2 sensor and drive the car, if performance improves you found your problem. Makes the car loud, but it's effective.
Mike Sargent
