98 4-runner rear brake job
Dunerking
Howdy all,luv the site! Thanks for all the help. Finished doing new rotors and pads in the front,now time for the rear drums. Just looking for a quick review of doing this job,trying to avoid costly errors. I would also like to swap out the fluid as well. Does anyone know the part number from Toyota for the rear shoes? Sorry for the newbie questions,I did do a search in the maintence section,but never saw anything directly targeting the info I need. Thanks again.
I ordered it from Amazon... here's the one I got:
Amazon.com: OEM 25056 Brake Spring Washer Tool: Home Improvement
I also got a set of brake pliers that helped in pulling to spring back onto the shoe during reassembly:
Amazon.com: OEM 25000 Brake Spring Pliers: Home Improvement
Actually, you might be able to just use the pliers. I think they have an end that serves as a compression/washer tool... However, the dedicated one was sooooo easy to use. It's a keeper. I'll be using a bunch on other jobs too.
Good Luck.
Good Luck.
thanks, just used these two links to buy these tools! I wanted to buy something known to be a good fit for a 3rd gen and these are that plus, dirt cheap, hell, cheaper than Harbor Freight.
Good Luck.
After doing this job I've decided that a small screwdriver to hold the spring in place then grabbing it with vice grips and muscling it into it's slot beats these spring pliers by a wide margin. These spring plier are not designed to work with the Toyota drum brake and scratched up my brake shoe more than I wanted while I was fumbling around trying to get them to work. When I finally got my technique together near the end of the job it because much easier than trying to use the spring pliers.
satxrunner
