Got a 99 limited 3.4 4wd. Pretty sure it's a california emission setup due to the fiasco changing the previous 02 sensors. Changed out for the Bosch before I found out not to. Anyway, got a little misfire action going on along with bad 02 sensors again.
Was going to replace all 3 coil packs since it has 270k on it and both 02 sensors. Do the coil packs need to the denso also? They are $102 at dealer and he only has 1. Are any aftermarket ones an acceptable replacement? Are the Cali emissions models like mine able to use standard coil packs?
Ok, how bout the 02 sensors? Is there a less expensive place to get the Cali emission densos?
Thanks in advance!
Thanks in advance!
