99 4Runner P1300 code
Hiluxsurf 2409
I need some help i have a check engine light on and the code is well i have 2 codes P0171 and P1300 but i'm more concern with the second code says igniter circuit malfunction friend told that part kind expensive and i need to know where is located maybe i can replace my self :thanks:
These 2 codes could point to the MAF. I would try to clean it first with MAF cleaner. (Pull it out, spray it down really good and let it dry before putting it back).
You'll also want to check your spark plug wires and spark plugs. The igniters don't often go out in these trucks, so my guess is that its a plug or wire.
hello
Thanks i replace the mass air flow meter so the p0171 is gone but p1300 still on can you tell me where is the igniter
Igniter
It is next to mass air flow meter toward fire wall. Should have 10 wire going into. Doubt that's it tho. When igniter goes car don't run.
delislerebecca
