99 4runner-will not start
pmg
replaced water pump, new timing belt, set timing with a master mechanic, and checked it three different times. Did not start, ran code scan- maf sensor code came up. Replaced maf , code cleared, and all other codes clear. Will crank but not start, ran fine before the repairs. Extremely frustrated, sitting in the driveway for three months now !
If it still doesn't start after ruling everything else out, I'd suggest taking another look at the reluctor teeth.
They can be installed correctly, but if they have even seemingly minor damage, the resulting erratic signal received by the ecu can cause a no-start condition, with no codes present.
Good luck.
2001ATL
