99 ACDelco Springs Where to buy
maddss
Member
Looking for a set of 99 tall springs, just trying to replace what is on the 4R now. Trying to keep replcement of the struts/coils on a budget.
ACDelco 45H0368 (also referred to as 19241929) are the only ones I see that area a direct replacement, but I cannot find them anywhere.
Any other suggestions ?
Did OEM Toyota discontinue them? As the 99 Talls were available a few years ago?
1999-2000 Toyota 4Runner Coil Spring (Left, Right, Rear) 48231-35210 | Camelback Toyota Parts
Part Numbers:
Front right 48131-35400 L=368mm
Front left 48131-35350 L=374mm
Rears ( same for both ) 48231-35210
Color Codes:
Fronts: Blue/Pink & Blue/Yellow
Rears: Green/Red
Clipped from a 2011 post of mine on YT
Still available, $115 each for the rears. Strongly recommend OME 906s in the rear instead at $214 for the rear pair. With Tall 99s in front, you have a nice slight forward rake and no godawful rear sag with load like the POS stock rear talls. I've had ten years plus on both.
I am not in favor of the 99 talls in the rear. Mine only lasted a few years before they were the like normal height.. :(
I am thinking next round I going ome...:)
I think with the 3rd Gen, Toyota was trying to get as "car-like" a ride as possible, which is why the OEM springs just sag so much with load.
erinobr2000
