99 sr5 highlander's Rear Swing-out Build
99 sr5 highlander
As I'm sure many of you know, a swing out tire carrier is an awesome addition to any truck. They not only allow you to carry a full size spare, but open up options for mounting all sorts of accessories, such as jerry cans, tables, high lifts, traction aids...
Unfortunately, with all this utility come a hefty price. A fully loaded bumper often runs upward of $1600. Being a college student, that is kinda out of the question, so if I wanted one, I had to get creative.
Luckily, I got the opportunity to build my dream bumper during a class over January term.
I had several requirements for my bumper after seeing several in action,
1. It had to be low profile, clean and simple looking.
2. The spare tire had to be as close to the body as possible and high enough not to drag on obstacles.
3. It had to be strong with very little flex, or tire bounce over rough surfaces.
4. And finally it had to have a jerry can mount, fold down table, and make the most out of the compact design.
In addition to their high prices, I couldn't find a tire carrier that I really liked and fit all my requirements.
First I had to come up with a design.
I briefly thought about making a mock-up out of cardboard, but it just wouldn't be rigid enough to create the design i wanted. So, a couple trips to the lumber store were in order.
From taking measurements with the factory bumper and hitch removed I knew that I wanted to use a 3x6" rectangle tube for the main bumper. I ant and bought 2 6 foot 2" x 6" ( actual dimensions are 1.5" x 5.5") to stack.
Here's the main bumper mounted using 1/2" plywood to simulate 3x4 angle iron. Also hung the spare from to roof rack to get a feel for the layout. At this point I chose to mount the spare on the drivers side because I felt it would be least intrusive for visibility, and a drivers swing would be best for curb parking.
Checking departure angle for tire.
Figured out angles and cut.
Making sure tire clears.
Went down and got some 3/16" plate, 1/4" 3x4 angle iron, and way more 3x6 3/16"wall tube than I needed.
Got the sides cut out with a plasma cutter.
Cut out the main tube to match my template, along with the frame plates. I must say, the plasma cutter is the only way to go. ( aside from laser, but that was out of the question.)
I decided to use the 4xinnovations spindle because of the strength of the dual sheer design.
Mounted on the truck.
Everything was tacked together first to make sure it was all square and fit the truck with all the proper clearances, then I flipped it so it would lay flat on the table and tacked the sides to the table, so heat wouldn't cause it to warp.
Got the main bumper fully welded and moved on to the swing arm.
I used 3x2 3/16" wall tubing, which is probably overkill, but I didn't want it to flex.
Made sure everything was level, and tacked on the arm.
Built the upright for the tire. I wanted to keep this close to the body while being strong enough not to bend. I used the same tube as the arm, just turned 90* and notched it to fit the tube. I cut pies out of it to curve around the hatch. It maintains about an inch of clearance to the body, but hugs it pretty well.
Cut a side support to add strength. I know most go with two, but I believe the angles and the 3/16" wall tube should be plenty strong, and it leaves room for the table.
Cut the tire mount, and originally was going to build it to be adjustable, but I wasn't happy with the strength, and it didn't really help the rearward visibility, so I decided to go with a solid mount.
Very satisfied with the tire positioning, and built a jerry can mount out of angle iron.
I decided to keep it just 1 jerry can to keep weight down and keep it tucked in close to the body.
Used a De-Sta-Co latch because it is the fastest to operate and I will be opening and closing it frequently.
Welded in a hitch receiver, and gusseted it in the same style as the factory hitch, so It should be as strong, if not stronger.
Finally, got it painted with Rustoleum bed liner. It has a really nice fine texture, good durability, and most importantly is easy to touch up when it gets scratched.
Made a table to fold down from the swing out. I designed it to fit a stove and maybe a pot or whatever for a camp kitchen.
Also added some removable hooks on the tire upright.
And finally some storage in the bumper tube for straps, gloves and other small items.
Overall, I couldn't be happier with the outcome. I learned a ton in building it, and certainly got better at welding.
Nicely done! The storage in the bumper looks like a water collection station though. How is it sealed?
Thanks, the storage is sealed with rubber weatherstripping, so water shouldn't get in. The bins are caped on the ends, so if water gets in there I'll be able to wipe it out. One of those things that I'll just have to see how it performs and adjust accordingly.
Nice job man. the gap between the wings and the body looks pretty small, any issues with it flexing into the body? I know my CBI did it until I stuck some washers between the mounts and frame to space it down
Thanks. No issues on the gap yet. Ive flexed it out on a dirt mound, but you know, new things happen out wheeling, so we'll see. I capped off the tops with thin sheet metal, so if it does ever contact the body, those should bend before the body does.
So...
When you going to make a market model?
Well, I've thought about it. But not yet. I need to get myself a good welder and plasma cutter first, but I have the mock up still, so we'll see. Ask again in a year and the answer may be different.
You are a ways from OR. Drove back from Manhattan last year and I thought I was never getting to Denver.
