99 talls?
1da4
Ok so i have a bone stock suspension 2001 4x4 limited. It just got new stock shocks when I bought it in may and new tires in October so I can't justify buying a whole lift right now but I wanna give it a little better stance, so can yall post some pics of 4runners with 99 talls on it? and does anyone know the exact part numbers they used for the coils?
Don't have a pic right now, but I replaced my rear coils with talls to combat the sag and I like it. I have a 2001 too. Since i didn't replace the fonts I'm getting a touch of rake, which I like.
If you are not looking to wheel, dont want much of a lift or are living with stock sagging rear spring (as we all seem to at one point) and just want to fix that then 99 tall spring are a great way to go and will give .5 to 1 inch of lift depending on year and spring wear. If you are planning to wheel or want to do a lift then save up and just do a good lift kit. My stock sagging springs with new kyb shocks do just fine off road for now as i save up for my lift.:popcorn:
part # for 99 rear coil springs
I just ordered the 1999 rear coil springs for my 2001. Here's the info: Toyota part# 4823135190 from Camelback toyota parts..online. no tax..to Ca. free shipping over $50.
I did shocks too KYB Monomax.
Thanks! I will probably be getting them soon
Definitely need to fix my rear sag, gonna get the rears first and if i dont like the rake then ill get the fronts to match
You wont have to worry about the rear having a rake to it. In most cases 99 talls level out the rear. They will sag under loads from most other peoples experiences.
These are the correct part numbers for 4WD '99 talls:
Front Right Coil - Blue/Yellow (48131-35400) Passenger Side
Front Left Coil - Blue/Pink (48131 - 35350) Driver Side
Rear Coil - Yellow/Red (48231 - 35210)
Thanks! appreciate it
This was how it sat before I swapped out my 99 tall with Superflexes. About 20" fender to hub (rear). In case anyone is interested, they are just rolling around in the back of my car, waiting for a new home.
What was your reason for the swap?
I just replaced front 01 stock coils, for the 99 talls along with some 4600 blistens ubj and a right cv axle. I got about 1.25" lift in front from ground I was 34.5" now sitting at 36.75".
Well I swapped because I wanted something other than OEM lift and more clearance and more travel and better off-roading performance.
Too pricey
Why the 99s when they cost more than almost every other option? I'm interested in a slight lift since I need to upgrade my 17 year old suspension. But OME 880/906 come to about $320 for all 4. 99 talls at Camelback are about $380.
Other than price, is the main difference ride comfort/stiffness? I read a positive review of Moog springs when run with Bilstein 4600s, and he added 1" with that set-up, for far cheaper.
DionicioLives
