99 won't start, no click
Gospinn
Howdy,
99 auto 4cyn...replaced the contacts, had starter tested...good. New StarterRelay, new ignition starter switch. New battery, grounded good.
I've also tried starting in neutral... Won't start with jumper cables ...bollo!
Dash lights all work, makes no engine or starter noises.
The clock is the only light that dimes when turning key.
Seized engine? :shrug:
How did you test the starter? If it spins off the truck using the truck's electrical system, then there's a bigger problem... not trying to jump to conclusions though.
Starter checked out good. It's all stock...factory alarm. No aftermarket alarm.
5 days back from Kuwait and frustrated....uuuhg!
I'm in the process of replacing both battery cables.
Thanks for the help!
Autozone tested my starter.
Sometimes you turn the key and it starts...other times nothing. Truck started 5 Days ago.
I'd say you have a bad starter. A buddy of mine had this same scenario. Turned out one of the big copper contacts in the starter had just burnt out over the hears. Tested ok because Autozone wont run a full current through it. When you hit it with full current/load, it failed.
Replaced both battery cables and connectors...still didn't start.
Out of frustration I started pulling and beating on all the cables going to the battery and on the starter relay fuse...mysteriously it started working.
Weird!?
Back in business for now:). Thanks for everyone's help...awesome site!
I used to hit the side of my tv to get it to work also. Guess, once in a while, you gotta show 'em who's boss.
Won't start when hot
So now it is randomly not starting when hot. Turn the key and no sound, no click, no turning over...dash lights all work, clock is the only thing that dims. Drove to get gas 10 min and wouldn't start. Wait 20 min and starts right away. Doesn't always do it...weird...any ideas?
Is "randomly" being used literally or in the colloquial? In other words, did it suddenly without a known correlation cease to start at all if hot, or does occasionally (without a known correlation) not start when hot? Also, where/what was jiggled that made it work initially?
With the information at hand:
It sounds like thermal expansion is causing whatever had a weak connection to lose that connection until it cools and contracts again. The thermal expansion could be taking place within the starter itself (which would cause it to test fine), or anywhere along the signal path back (obviously in proximity to things that get hot). Given the successful jiggling, I would start at the starter terminals and see if there is any movement at all within the starter itself.
There's also the possibility that some wires got where they weren't supposed to go and some insulation was melted. When the part that did the melting is hot, the culpable wire is grounding to the engine versus carrying the signal/current through to the starter itself. That could also potentially cause lights to sporadically dim (unless you're talking about the dimming that occurs due to the additional power draw typically used by a starter) as power is effectively shorting through the block (though with enough resistance to not blow a fuse). The net result is effectively the same: follow the starter wires all the way back to the source only look for melted wires in addition to loose connections/worn electrical parts.
An automotive multimeter would be a good investment here if you don't already have one as it can be used between wires and components to see if/where the connection is being lost.
Started fine on 5 other occasions today while running errands. Tried the pulling on the wires today...didn't have the luck like the other day. The two other wires that run to the positive side both look fine and the small wire to the starter is good. Nothing looks melted. Also just started it and the clock dimming is normal I guess.
Do you have a remote starter? When my truck sits in the sun, the remote starter, or the wiring to it, acts up and the truck will only start with the remote.
I would suggest a Loose ground wire someplace that allows it to start sometimes and others not.
had this happen to me, was the front wiring harrness had a short in it. on a side note, after lurcking for 4 years i made a post :)
No remote starter, all stock. I have verified everything I can see for lose wires. Definitely happens after driving...hot, just happened again. Luckily near restaurants so I had lunch. Cooled off in the parking garage and started right up after 45 min.
Sounds like a loose connection.
I would be tempted to check fuses/relays. Heat has a substantial affect on smaller electrical components like what you find in a relay.
Maybe check if they are all seated properly and operating correctly.
I had a faulty main relay in one of my cars and caused a no start situation.
MMJR_T4R
