A/C Problems
Mark86
Super Moderator
While sitting in traffic, my truck blows hot and humid air from the vents. When I start moving again, the air starts to get cool. In addition, the air sometimes blows hot and cold while driving. Any ideas what could be wrong and how I can fix it? Thanks in advance!
Well I have the V6 so I don't know where they put the sight glass on the V8. On the V6 it's just behind the grill , a small box with a black pipe entering one side and exiting on the other. If you can locate this. turn on the A/C with the engine running and look closely at the sight glass looking for bubbles. If you see bubbles it means you are low on refrigerant. Also check your A/C light to see if it flashes when you are not getting cold air. If you see this it's our old friend the compressor clutch relay malfunctioning. Best bet is to take it in for diagnosis and repair, somewhere you trust. Good luck!
I agree drmorbius and would add: If someone tried to charge it but added too much refrigerant it could have similar symptoms. Either way it sounds like an improperly charged system.
:cheers:
I checked for bubbling and there was nothing. I never had the unit recharged either. The sight glass is located in the same place on a V8. I guess I will ride it out and hope that this doesn't happen again. I didn't notice the A/C light blinking when this occurred. Thanks again!
