RandyBobandy
Yes I kept the J shift transfer case that was attached to my auto, I’ve considered attempting a multi mode swap after I get this all finished up
Is that multi mode tcase and wiring a self contained unit that would swap into a non multi mode vehicle, or does it interact with the ecu or wheel speed sensors in some way?
It took me a long time to figure out where those wires were. Basically you need to find those wires on the e9 and e11 plugs and run them back over to the ecu engine harness plug. I just spliced and soldered the connection. I am too tired to wrap my he'd around exactly why they are run differently but if you unwrap the tape on the auto engine wiring harness those 2 wires run about a foot and then bend back to the e9 e11 plugs and don't run back down to the engine. Anyway they are in a different plug so you just have to manually move them over. The 97 was very different from the auto to manual in the wiring
No They are on the dash side of the e9 or e 11 plug (the bigger one if I remember) Just add an extension and run them into the proper spot on the ecu
