A New version of "Entune" is available!
I have tried 3 different USBs all formatted FAT 32 with the swdl.iso file on it.
Followed the instructions and ZERO, ZILTCH, ZIPPO.
I even renamed the volume to 14A, 15A, and 16A and NADA!
I got my 2016 TEP in May so this would be an update for it.
didn't work for me either. Just dragged the ISO file into a usb drive and followed instructions. Radio didn't even notice the drive being inserted.
This might help for those having issues:
1. Make sure your 2G USB drive is formatted (empty)
2. Remember to UNZIP the swdl.iso file before transfering to USB
3. Use different USB device if one you used fails.
4. Use reliable Zip software to extract this file (some have freeware and tags your files when extracted.
GL
Isn't there an "update software" menu choice someplace? I can't remember and don't have my truck available at the moment.
There is. I tried that too, not highlighted to give option. Does anyone know if the update can be done over the air?
GL
Did ALL of this and it doesnt work.
Worked for me on my 2013 TE. This is probably the 3rd (or possibly 4th) time I've done an Entune system upgrade since I've had the vehicle, always without incident.
Worked for me as well. FYI guys, this is more than likely for 2012-2013. I don't believe there was Entune in 2010-2011? and 2014-2017 should have a newer edition of Entune so those are updated OTA.
Below is the update log for those interested.
********SOFTWARE UPDATE LOG********
Value read from FRAM is 0
This is a NA Unit.
ERROR:could not open version.txt file from target
Starting Update
Total units to update: 8
Installing unit 1 System Check
Power sense circuit Ok
dev-ipc operation start
Requesting swdlToyotaManager for IOC Version
IOC version received
ioc application version 1.6.20
ioc bolo version 3.2.0
SUPPORTED IOC Bolo version 3:2:0
Supported bootloader
Installing unit 2 System
Operation on etfs : start for unit System
Updating ifs partition 0
update ifs done 1
Updating IPL partition 0
update ipl done 1
Updating ifs partition 1
update ifs done 2
Updating IPL partition 1
update ipl done 2
Updating ifs partition 2
update ifs done 3
Updating IPL partition 2
update ipl done 3
Updating IPL partition 3
update ipl done 4
Operation on etfs : stop for unit System
Installing unit 3 System Data
mmc driver operation start
mmc driver operation umount
mmc driver operation mount
percent = 0%
status.value = 0, status.string = success
percent = 11%
percent = 23%
percent = 34%
percent = 44%
percent = 54%
percent = 58%
percent = 64%
percent = 78%
percent = 96%
percent = 100%
qkcp done
mmc driver operation stop
Installing unit 4 Cleanup
Operation on etfs : start for unit Cleanup
Removing /fs/etfs/db/mme*
Removing /fs/etfs/var/kona/xletsdir/xlets/80ae9770-dde1-11df-85ca-0800200c9a67/data/skip_info
Removing /fs/etfs/var/kona/xletsdir/xlets/f73472f0-b7b8-11e0-aff2-0800200c9a66/data/iheart_streamlist.info
Removing /fs/etfs/var/kona/xletsdir/xlets/f73472f0-b7b8-11e0-aff2-0800200c9a66/data/iHR_LR_update.info
Removing /fs/etfs/var/kona/xletsdir/xlets/80ae9770-dde1-11df-85ca-0800200c9a67/data/bk_skip_info
Removing /fs/etfs/usr/NNG_save/
Removing /fs/etfs/var/kona/xletslib/location.jar
Removing /fs/etfs/speech_service/dialog/grammar/MATCHER_CONTAINER_MMEDEVICE_*
Operation on etfs : stop for unit Cleanup
Installing unit 5 Apps Cleanup
Operation on etfs : start for unit Apps Cleanup
Removing /fs/etfs/var/kona/amslib
Removing /fs/etfs/var/kona/security
Operation on etfs : stop for unit Apps Cleanup
Installing unit 6 Apps
percent = 0%
percent = 32%
percent = 69%
percent = 100%
qkcp done
Installing unit 7 Speech
percent = 0%
percent = 1%
percent = 3%
percent = 4%
percent = 5%
percent = 8%
percent = 10%
percent = 13%
percent = 13%
percent = 13%
percent = 15%
percent = 18%
percent = 21%
percent = 24%
percent = 26%
percent = 29%
percent = 32%
percent = 35%
percent = 38%
percent = 40%
percent = 42%
percent = 44%
percent = 47%
percent = 48%
percent = 49%
percent = 52%
percent = 55%
percent = 58%
percent = 60%
percent = 63%
percent = 66%
percent = 69%
percent = 71%
percent = 73%
percent = 76%
percent = 76%
percent = 77%
percent = 80%
percent = 82%
percent = 84%
percent = 86%
percent = 89%
percent = 91%
percent = 93%
percent = 96%
percent = 98%
percent = 100%
qkcp done
Installing unit 8 AVC-LAN
Not in bolo mode, will put v850 in bootloader mode
This is a NA Unit.
Starting Update
already in bolo mode continue with ioc update
ioc update done
Software Update successfully completed
Eject USB for RESET
ERROR: Software update complete
Thanks so much for the discussion. I still am not getting it to work, maybe I will try again later to see if there is something I am missing.
I went to the toyota site (https://securedp.toyota.com/download-app/toyota) and downloaded the zip file (0139-HBEKR-16A.zip). I extracted the iso file from it and then drug and dropped it to a freshly formatted (FAT32) USB drive named 16A.
I have a 2014 Limited with premium sound.
I am having problems with connectivity sometimes which is why I was looking for the update. But it is not too bad, just a little annoying. I can probably wait until my next maintenance visit and have the dealer do it, if I don't figure it out first.
Yours might already be updated the way mine was through the Entune app just running ... its the older models that dont have that capability.
2013 TE here too...never any issue with an update.
Display Audio with Navigation and Entune® App Suite-Update Type – Multimedia operating system / Gracenote / Entune App Suite
1. What should be on my USB memory Device
1) Download the update file contents onto your computer.
2) Double click on the file, which should open a new folder with a file named "SWDL.iso" inside it.
3) Insert your USB flash drive into an open slot on your computer and open a view of your flash drive as a new folder.
4) "Drag and Drop" the "SWDL.iso" file to the folder representing your USB flash drive.
5) "Eject" your USB flash drive, remove it from your computer, and take it to your vehicle.
2. Software Update Procedure
1) For this and all following steps, keep your vehicle parked in a well-ventilated open area outside, suitable for running the engine, not in an enclosed structure such as a garage.
2) Start the engine ("Ready" mode in hybrid vehicle models).
Note: Turn on the Radio.
3) Press the “Apps” button (the system will switch to the Apps main page).
4) Install USB Drive into vehicle’s USB port (there will be a short pause while the software version is read). The USB port is usually located below the audio system, in the console box or in the glove box. Refer to your Owner's Manual "Using the audio system; Operating a USB memory" section for the precise location in your vehicle.
5) An “Update software from X.X.X to X.X.X?” message will be displayed.
step image
6) Press “Yes”.
7) A “Please do not interrupt the software update once it has started. The engine must be running during software update.” message will be displayed.
step image
8) Press “Confirm” (the engine must be running or hybrid system in Ready ON mode during software update).
9) The Software update will begin and the screen will show a “Package 1 of 8” message, and continue through 8 of 8. It will take approximately 5 minutes for the update to complete.
step image
10) When finished, a "Software update complete" message is displayed.
step image
11) Remove the USB Drive.
12) Turn the vehicle OFF.
3. Check your current multimedia software versions
1) The software update is finished, but if desired, you may confirm that software version level reflects the updated version numbers by executing the following steps.
step image
2) Press the “Setup” button.
3) In Setup menu press “General”.
step image
4) In the General Settings menu scroll down and press “System Information”.
step image
5) In the System Information menu the Software Version information is displayed (eg. 5.1.0).
step image
2012 TE just updated. I think the key is extracting the file after you download. I doubt it will work unless you do so. I haven't had a second to check out the changes but I am hoping for some improvement since I went from version 1.7 to version 5.2...
What did you name the volume of the USB?
Didn't rename drive, used a 2 gig flash drive I had laying around. Downloaded file, copied to drive, extracted all. Opened new folder, selected ISO file, then navigated back to main page of flash drive and pasted file. Deleted all other files on drive.
Plugged drive into truck, turned on ignition and radio, within a minute or two display prompted if I wanted to update from version 5.1.xx to 5.2.xx, selected yes, software installed, done.
Yea, I messed up and didnt realize this is for 2013 and older 4Runners.
Hey [MENTION=81322]barryhiram[/MENTION],
Last September I learned that there was an O.S. update (5.1) that was said to resolve many of the issues that My truck was having e.g., trouble with the audio system playlist/track advance & back buttons inoperative, daily phone BT pairing, connectivity issues... etc! So I dropped in the update (swdl.iso) and all of those issues, after three years, miraculously disappeared! So now there's a newer (swdl.iso 5.2) update.
(Question:) Why did you become interested in this update; were you having issues with the phone, the audio system, navi system... or did you swap out the O.S. software as a precautionary measure or because it was available? Also, has anything changed resulting from the update? I'm just trying to decide if I have reason to refresh the software or "to leave well enough alone"... after all it is working just as it should now (knock on wood)! Thanks bro!
"Best to you"!
ahhh I wasted an hour just now trying to update
and then saw this post that its for 2013 and older.
it doesn't apply to my 2015 trail.
I take it no update applies for the 2015s even though this new update dropped 2 days ago?
