mechagouki
If you've seen my other recent threads you'll know that I have been looking for a new Runner to replace my '90 2 door, which i stupidly sold in June. After coming close to buying a 2nd gen 5 speed V6 and even considering a 4 cyl diesel Land Cruiser i think I may have found my truck! I'm not very knowledgeable though so I need some questions answered, the truck is an 1989, 4cyl 5 speed 4WD:
1.The lower front of the engine is quite wet, the seller says the previous owner fitted the gasket incorrectly after replacing the timing chain, and that it's a very slow leak that has no adverse effects - does this ring true, and if it needs fixing, is it an expensive job?
2. There appears to only be one shock absorber in back, on the passenger side - is this normal, I can't see a mount on the driver's side?
3. Tailgate has some penetrating rust and the window is stuck, will this stop me removing the cap, and when I come to work on it, are the innards similar to a 2nd Gen?
4. Anything else I should look out for? The seller has replaced all the brakes, fixed the fender rust and the truck is wearing a brand new set of General Grabber 31s, most of the front end looks newish, seller claims to have replaced most of the steering and fitted a new damper, the truck feels tight and solid when driven.
Thanks for your help!
