A/T oil temp warning light and battery warning light concern
arki01
Hi guys. I was driving a long drive then suddenly engine stops and A/T oil temp and battery warning light turns on, and when tried to start engine, starter makes a sound but, engine won't start. Timing belt is ok, battery is good, A/T oil is at correct level as well as engine oil. Any similar situation and what did you do?
By the way, it's a 1997 4Runner.
Thank you.
Thank you.
What did the manual say about it?
Im assuming the A/T light and batt light just came on because the engine stopped and are not a sign of something wrong.
Start with the basics air/fuel/spark. engine cranking so battery has power, maybe fuel pump died? gotta be fuel or spark.
Any engine codes? does it sound normal when cranking over?
No engine code as only a/t oil temp and battery warning light was on. Cranking sounds seems like it's the starter only that's making a sound. Car was running then suddenly, engine stops.
