ABS Module replacement?
ÆonOfHorus
Hi all. A few months ago I replaced my shocks, and several days later, my speedo and odo stopped working. A local tire shop did a scan and found it was showing a P0500 (Vehicle Speed Sensor) and C0210 (Rear Speed Sensor RH Circuit). I checked connectivity from the rear right speed sensor all the way to the rear wiring harness and it seems to have continuity.
I took it to another mechanic today, finally, and he says it's got the following codes:
C0226/236/246/256 (brake booster solenoid open or short circuit, all four)
C1201 (Engine control system)
C1223 (ABC control system)
C1225/1226/1227/1228 (solenoid error similar to above).
He's suggested that I should replace the ABS module, but doesn't seem terribly confident. Has anyone had something similar? I imagine if I just took it to a dealership they'd charge me a few grand and likely do very little.
Did u ever find any answers I'm having the same issue after my hydroboost motor gave out i replaced motor and bled master cylinder my brakes work fine but I have my brake light abs trac and another light lit up with the same code for brake booster solenoid circuit open or shorted and a abs malfunction code Iv checked most of the wiring the only thing I can think is maybe I swapped the + and - on the motor but again I don't know if that's even possible and of course I'm due for inspection Im really hopeing me ecu is not toast
man, i've been battling this as well. have c0210 and c1223 code. changed ABS sensor harness, Changed 3 abs sensor. I found out my rear right bearing was smashed in 10 pieces, new bearing, axle seal, retainer etc, still have the c0210 code. gonna try another sensor see if that changes.
ShiftHarbor683
