ABS on 2013 limited
Is this a serious question? Its not a switch you can turn off. Its completely integrated in the vehicle.....like most vehicles in the last decade.
Do you mean the traction control? Why would abs be a problem? You want to lock your breaks up? Traction control can be turned off by using the appropriate button...
Funny, I added a switch to my 07 Taco to turn the ABS off. That thing, if a wheel slid just a tiny bit, it would completely release the brakes, then maybe start trying to apply them again... some time later, maybe miles down the road. OK, not really miles, but literally, several hundred feet.
4Runner's ABS has never been an issue on road, and it seems that turning on MTS or ATRAC either disables it, or makes it extremely unintrusive, to the point that I can lock wheels in sand/dirt and dig in to stop.
I haven't tried on the 4runner but on my older cars you could pull a relay or fuse under the hood. Might be worth looking into if you really want to disable it.
