AC blowing hot after rear window repair
coondog704
I had my rear window repaired at the shop after one side stopped rolling up completely. When I took my truck in my AC worked perfectly when I picked It up its blowing hot, anyone have any idea what this might be related too? its extremely frustrating. :doh:
Stupid question, but did you push the A/C button to make sure AC is on and the light is on??
There's a temp sensor connected by a yellow harness behind the trim piece below the steering wheel. Like with the ignition and the little fuse box and switches. It's on the right side, where you can see some slits in the trim piece. If that's disconnected, you'll only get cold air on lo, every other setting is hot. I don't know why'd anybody would mess with that if they're fixing a window, but it's worth a shot.
H.Sikina
