AC compressor questions
fblainen11
So I changed my timing belt and while doing that I noticed my AC clutch and tensioner pulley were bad. I replaced both of those but the clutch was bad. I figured it was probably because the shaft was damaged when the bearing went bad.
Questions:
Is there any possible way to just replace the shaft?
If not, what is a good compressor to get?
I can get a mechanics price if I purchase it from Oreilley's. any help, answers, suggestions are appreciated.
Thanks in advance.
I think Denso # 471-1164 has all that you want. $200 at Amazon but am not sure if Oreily's carries it. Four Seasons is #58362, but you will need a puller to get the old pulley off the OEM compressor.
Don't forget a new drier.
AlaskaRuss
