AC Issue
JRFlo
AC blows warm air, when looking at the sight glass no bubbles appear, the low pressure side is warm to the touch and when the compressor is turned on its starting to make a weird noise.
Any thoughts?
A noisy compressor could be caused by the clutch being worn out and its slipping and having metal to metal contact. You also need to check the psi in the system with it off then see what its at when the compressor turns on. The compressor can also lock up, If it does it will take your belt out and the belt may take other things out when it breaks. you need a set of a/c gauges to check the psi and go from there based on the readings you get.
