Acceleration/hesitation issues
Jdhulse74
Have a 2001 t4r with ~280k miles. Have recently had issues with acceleration. It initially started happening when hitting about 1800 rpm on acceleration and would hesitate, as if it was towing a heavy load up a hill. I went ahead and changed the spark plugs and wires (both NGK) and the fuel filter, but the problem still existed. I put an ohm meter on the fuel injectors and they were within normal limits. Then things started going south...the RPMs would shoot up to 5k on startup and stay there. I checked the throttle cable and it was not sticking. I found a 4 pin throttle position sensor, installed it, and it corrected that problem. I went to take it for a test run (idles fine on startup) and the truck hesitates when attempting to accelerate. I heard an air leak from somewhere, got up under the vehicle, and found a hole in the weld bead where the O2 sensor mounts on the exhaust. I ordered a magnaflow from exhaust/catalytic converter and went ahead and got a new O2 sensor as well. Started it up, went to accelerate, and the same thing is happening. I am at wits end And hoping that someone on here has had the same issues before and can shed some insight.
Changed the TPS, and there is a check engine light. Unfortunately, I cannot make it up to an autozone or advance auto to get it read. I had it tested previously when the issues first started happening and it was p0300.
Coil pack sounds fair to me
Also, whats the condition of your MAF? have you cleaned it lately?
And the throttle body, is it clear of carbon/oil build up?
Cleaned the MAF and the throttle body. They should be pretty much spotless. I can purchase a coil pack and swap it around to see if any of the three are bad.
tuṣṭāva
