accessing top of gas tank
gimme789
I have a gas leak in my 95. I think it's coming from the top area of the tank.
( sender unit ? , gas line ?)
I don't think its the tank itself. Also, it leaks worse when its running.
Is there any way to access or see the top of the tank, without dropping the tank itself ? maybe an acccess door from the top ?
anyone ever take a tank out ? how tough is it ?
if its an easy fix, I'll probably do it, else, it may be time to retire it (:
It still runs well though :) - even with the leak
TIA
If it's anything like a 1st gen there should be an access panel under the passenger side rear seat. A few screws and you have full access to the tank top, including the fuel pump and sender unit.
Yup, what Pyro said--three screws under the passenger side rear seat and you're in. Dropping the tank isn't a major challenge, either, except the filler- and vent tubes can be tough to break loose. Best of luck!
thanks guys, its raining today, so probably wont try it, but I'm hoping I may be able to fix it without taking it out.
TIA
Your leak is most likely from the the pump/pick-up assy.
They rust out where the metal tubes go into the top mounting plate, creating the leak. The leak is worse when running because the fuel is under pressure.
allcarhistory
