Added DRLs to a '99 SR5 T4r
Drcoffee
Senior Member
Now if this was my DD, I would run dark but this truck was bought for my kids to use and anything to help prevent an accident is worth considering. One of the first mods was a flashing high mount brake light. It flashes 4x then goes solid when you press the brake pedal. It resets after 20 seconds so it really only flashes when you first hit the brakes.
www.3rdbrakeflasher.com
Today I added two LED lights to the fog light covers to turn on only when the ignition is in the on position and I used the factory fog light wires. Last time I was at the bone yard I pulled a few Weather Pack connectors to connect to the factory wires behind the bumper just in case I needed to remove or change them later.
I found these sealed LED lights on Ebay for $13/pair which fit into a 3/4" hole with a supplied grommet.
Ebay lights
ry%3D400
If you ever need to drill clean holes, this RotaBroach drill bit set is invaluable. It cuts perfect holes.
ry%3D400
Install the grommets and lights and wire it up.
ry%3D400
The fuse box under the dash has several circuits you can choose from. I used a "Add a Fuse" and tapped into the turn signal circuit. It gets power only with the key in "ON" so its perfect for DRLs.
ry%3D400
Next I ran the wire from the dash up to the fuse box under the hood by the battery and connected it to the fog light circuit in the relay socket (18ga wire).
ry%3D400
Go underneath the bumper and cut back the wire cover a couple of inches to expose the factory wiring.
ry%3D400
If the lights don't light up, reverse the connection. The current can only go one way in an LED light.
Pink is (+)
White is (-)
They are very visable (hard to tell from the picture)
ry%3D400
Becaue these LEDs pull only 20mA each, these will not affect the turn signal circuit at all but again, these are protected by a separate 3amp fuse under the dash.
DJNutshell
