Addicted Offroad's Double Cab. Project "Frenchy"
AddictedOffroad
We are building this for a customer up in Dillon, CO.
Its a 2001 Tacoma Double Cab. Elocked. Pretty mild rig to be honest.
The plan is TG kit "C" which some mods to lower the ride height. We are going to french the springs hangers into the frame/crossmember up front to help lower the ride height. Customer plans on 35s for this rig, and I am confident we can deliver it with a frame height around 24" on TG leafs.
The rear will be more of the same with custom frenched spring hangers to lower it.
We already have it on the lift and have started assembling the front axle. FWIW, the TG Rock Assault housings have come a long way in quality since they were first released. Its a nice piece and much better than stock. Its still not a Diamond, but its good for the weekend wheeler and DD that this truck will be when done.
The rest of the build will consist of 5.29s, ARB up front, and 35s. We will also be building custom front plate bumper instead of our normal tube bumper for these.
Okay, so we mocked up the front hanger. Pics and measurements should speak for themselves.
First of all, we don't use TG's front crossmembers anyway in these kits. Theirs are .188 wall and an inch taller than ours to begin with. We use our Tacoma weld on crossmembers for our bumper instead. Ours is .250 wall and an inch shorter.
In this case we wanted to french the front spring hanger. So, we notched our crossmember to allow us to mount the new spring hanger into the frame. This saved a solid 2.875" of height here. That will equate to roughly 1.5" of lowered lift height.
TG's crossmember with their spring hanger is 7-3/8"
Our crossmember with french hangers is 4.5"
TG's
Our's
TG's
Ours
crossmember in place. Recessed back and frame is notched to allow more clearance. Steering is going to need a flat pitman arm, and we will llikely be notching the frame for clearance of it as well.
2001ATL
