adding extra power outlet
CRDT4R
I remember seeing some posts with someone adding an extra cig lighter. I have most of the items to do it but I can't find the post. There is one guy with a canadian flag that i have seen but there is another one from someone else which i can't find. The person mounted theres under the drivers side by the emergency break pedal.
If anyone knows where this post is, could they point me in the right direction. I have searched and searched everywhere
CRDT4R said:
I remember seeing some posts with someone adding an extra cig lighter... but there is another one from someone else which i can't find. The person mounted theres under the drivers side by the emergency break pedal...
I know the thread you mean but I can't find it back.
It's the thread that gave me the idea to look around and where to mount mine. I find my location to the right of the steering column very handy for the centre console.
well i completed the task, I Found the correct power outlet with the bracket. It looks really nice and clean but if you do not want it to have constant power, can you place the build a circuit in the CIG fuse?
Re: Re: adding extra power outlet
This one? You have it in the DIY sticky...
http://www.toyota-4runner.org/showthread.php?s=&threadid=49919
CRDT4R, any pics? Yes, the cig fuse should be just fine. The total load of all outlets can't exceed the rating of the cig fuse, obviously. A spotlight and a compressor simultaneously might be an issue.
:cheers:
thats the one i used but there was another one I was looking for. I put it in the same location as the the post which I like a lot and it works great.
has anyone seen this before?
http://www.dealextreme.com/details.dx/sku.2260
it might not be as clean but maybe the outlets could go in that useless cubby below the A/C controls and the swiches maybe on the side of the shifter? or in the center console?
Edit: i just remembered, it's not an always on power source since it's using the existing 12V outlet, however, if u rig up the extra one w/ the always on power source, then this wouldnt' be that bad of an idea? ... just a thought
i thought about those but it is just too big and bulky. you can barely even see what I added. If i were to get that though I would put it on the passenger side somewhere and make them deal with it.
Re: Additional 12V - constant power mod
THEREED said:
... Here is the one I did...
Thanks for the link. That's the one CRDT4R and I were referring to earlier that gave us the idea to copy the location.
