Adjusting Coilovers
Aelfwine
I have recently installed the toytec boss lift. Currently my front sits half inch higher than the rear. I didn't notice it at first and got my alignment done. My question is if I lower the front by adjusting the coilovers would it get my alignment out of spec significantly? Also what is the proper procedure for adjusting them?
Thank You!
Thank You!
Bump. I too have the same question
yes, it would only mess up toe i assume, only a little bit that is. most alignment shops will throw it back up on the rack and adjust that pretty quick if need be for you. maybe flip em a bit more coin. just to talk to them.
but like stated above. you should get another alignment. :keyboard:
Check around your area for place with a lifetime alignment. I see you are in Canada but here in the US at Firestone you can get a lifetime alignment.. you pay a little more upfront but it costs about what 2 alignments would be.
Plus if you end up wheeling and breaking something like a OTRE and you do trail repair you are going to be out again. Plus wheeling will throw it out too. I am going to do this on my next alignment.
