adjusting idle
trd_4runnin
When I come to a stop light or stop sign my 4Runner starts shaking and rattling really bad (after I'm already stopped.) After going from neutral to drive a couple of times I have figured out that this goes hand in hand with the RPM. When stopped in drive the truck idles at about 550-600 RPM and shakes like a crack-head that needs a fix and when I put it into neutral the RPMs go up about 100-150 and the truck settles down.
Im thinking its a motor/tranny mount, but since I'm in no position to be replacing a motor mount I want to raise the idle just a bit so that I will still idle at a safe RPM but enough so that it won't rattle so bad. How can I adjust the idle?
it sounds like you need to clean the carbon deposits out of the throttle body and attached sensors. i had the same problem and after cleaning, the engine is silky smooth.
I already cleaned out the throttle body and IAC valve but have yet to do the MAF. When I cleaned the other two it didn't make any difference at all.
The idle is computer controlled so you cant adjust it. Are you sure you dont have a misfire or something making the engine run bad? You really dont see motor/trans mounts go bad in these things
Sucks about the idle. It doesn't really seem like the engine is running bad, it just shakes the whole 4Runner. It's definately not a misfire and the truck runs top notch except for at this RPM. I have cleaned the TB and IAC and replaced the spark plugs.
toytech76 said:
you have another issue then. Idle should be 600-750 rpm I think. It should also be smooth
Idle around 600 is where its at in drive when stopped and shakes like crazy. When I move it to park or nuetral is goes up to 700-750 and runs very smooth.
