Adventures of 4RnR Grl (and build)
How about the switch you mounted next to the dual volt meter? Where did you get that? It looks pretty good mounted flush. I could use a few more switch spots mounted flush like that.
The red three-position switch came with the Blue Sea Automatic Charging Relay.
Is the meter always on?
Yup. I like to be able to peek in and just grab a quick glance. Maybe I'll add a switch later.
Dual Sub-Woofers?
Absolutely!
So I didn't post any pics from the last trip. It was incredible and I'm still on a high from it.
First nights camp site view.
Maiden voyage for the Antman built cargo box and table (it was incredible).
My cot tent worked really well.
Such an incredible view.
Ok... day one (fri).... the enormous windmills.
Dolly Sods.
Night two camp site. Really awesome site on the Canaan Loop.
More incredible views and a river crossing.
Third nights camp site.
Parting ways on Sunday morning. They finished the trip while I headed home.
Also video here:
Canaan loop: https://youtu.be/VEKfGUwmzjo
The mud reel (the best video): https://youtu.be/FV9ODpBfnko
The bog trail: https://youtu.be/j7_h33Ana74
Road before river: https://youtu.be/AKSu3Lm-cJ8
Today's adventure was with my hubby's racing club. They had a dyno day, so I thought, why not? And ran home to get my truck. $75 for two pulls... although it took them a bit to figure out how to run it (more like 4-5 pulls). Best was 229.7 (my guess was 230), printout shows 226.7. I didn't really care what the numbers were, so it was entertaining for a performance shop that mostly works on Audi and Volkswagen. They said I had the most unique vehicle they've ever had in their shop...
Then I hauled hubby's race car home lol!
Print out from second pull.
Video here: https://youtu.be/7_jLihMNYyc
NGP does good shit! I've owned a few VW's and they were my go-to shop.
Hubby's got a nice NA.
Well... time for an update....
Installed my snorkel last night...
1. Absolutely buy the fender liner clips.
2. Do not start this install after work when you have to get up at 5am... [emoji23][emoji23][emoji23]
3. Have small hands.
4. Have incredible patience.
5. Use a vast vocabulary of select expletives.
Here's my tool layout
I haven't washed my truck for awhile so I hit it with some quick detailer.
Here are the fender liner clips...
And what most of mine looked like after removal...
The fender liner removal turned out to be incredibly difficult and time consuming.
I did not remove it all the way as I couldn't afford to break any more clips.
Taking out the airbox components.
Fancy template placement, which I checked about a half dozen times.
Farewell message to my fender.
I used a dremel and heavy duty cut off wheels. It worked well and was easy to maneuver. I bought some metric step bits which worked perfect. Applied the paint and moved into the garage.
Marked and drilled the A-pillar. This was a nervous moment.
I have the TRD airbox... I DID NOT remove 25mm of material as the instructions stated. It was obvious to me that doing that would not leave enough of a lip for the rubber and hose clamp. Looking at the picture it was clear this part of the instructions should be different.
I did choose to seal up the bottom of the airbox with silicone.
Annnd.... done.
I have really enjoyed your build/adventure thread, thank you for taking all the time and trouble to post everything. LeonG, 2000 4Rnr SR5 LTD, (my second) & 1963-71 Triumph Vitesse Convertible (much modified under the skin).
I ran the Canaan loop today with the boys. I had such a blast in the snow. I ran this loop in June with [MENTION=137555]Sleeter[/MENTION] and it was awesome. With the snow it was so amazing.
I also did some scouting for the spring trip in Bald Eagle on Monday. It was awesome being out there with the fresh snowfall.
Another long day in the truck netted some more great snow shots. I drove into a winter storm warning this morning to scout some of the trails for the April trip. When I left the Baltimore area around 6:30 am, it was about 46 degrees. The high temp in the mountains was about 18 degrees. Last night the area was under a flood warning, temps dropped and the rain turned to snow. I drove through an area that was flooded then got onto the forest roads. By the time I got back into civilization my rear doors had so much ice and snow under them (over the sliders) that they couldn't be opened. It was a fun day and just beautiful.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Hi from another MD girl! NGP are my BOYS - been going there with my VWs and Audis for 10 years. Hands down the best shop around. Maybe they'll start working on 4Runners so I don't need to go anywhere else! :juggle:
Awesome build thread! I'm heading down to New River Gorge WV this summer which will be my first (mild) off road trip in the 4R. Not far from where you were, looks like we'll be making a pit stop in Monongahela park!
I’m a little late but loved the West Virginia pictures. My family is from Tucker County and my Aunt owns Sirianni’s Cafe in Davis near Canaan! My grandmother owns CJ’s Pizza in Parsons which is just down the mountain from Davis/Thomas.
Well... It happened. Finally got the Rear bumper on....I still need to tie up some loose ends (on the tire carrier) but......
Sent from my VS501 using Tapatalk
[MENTION=48772]Jesse1983[/MENTION] Spam bot got me. [emoji50][emoji50][emoji50] See above.
perarenato
