Advice on boat rack
Porter
Hi All
I am a first timer on this forum, but have been really impressed by the collective depth of knowledge and advice posted here.
I have a 2012 4Runner - Trail Edition.
:fishing: I am exploring options to mount a boat (10' pram: 10′ Hopper II | Spring Creek Prams) on the roof of my vehicle and came across the Rhino-Rack side boat loader (Rhino Rack - Side Boat Loader - Take the Tinnie and Tow). The information on the Rhino-Rack says that the boat rack weighs 50 lbs, and the pram weights 110 lbs.
When I checked the stock roof rack on my 4Runner, it says that load capacity is 132 lbs when loaded evenly...
In your opinions, is this a non-starter, i.e., too much weight for the roof rack and should I think about something else?
Thanks so much for any insight and advice!
Porter,
I exceeded the factory roof weight recommendations on my 2008 Tacoma. I had a Yakima dealer install a full Yakima set up with the mounts, cross bars and kayak cradles. I had two yaks that weighted appox 60lbs each. The clamps dented the roof really bad after I loaded the boats on there a few times. It was approx $600 at the body shop to pull the 4 dents and repaint. Since the boat you have is only 10' I would recommend researching a trailer, or possibly explore a way to secure it in the cabin of the 4 runner. I am not sure if that is feasable. I can say after a long paddle, I never looked forward to humping the boats on top of my truck. I was usually exhausted and feared I would drop the boat on the roof or the hood.
Just my 2 cents. Worth what you paid. Good Luck.
I have heavy kayaks - one is 80 lbs, the other 70 lbs. The only way I would use roof racks to carry one of them is if it was low enough to not be such a PITA - like maybe a station wagon or 2wd truck.
I use a utility trailer that I converted to a part-time kayak hauler. That's been MUCH easier.
roof rack...
Thanks for the comments... I actually do have a utility trailer that I currently haul this little pram in. The rationale for my question is that I am planning to haul a small camper and would like to take the pram along too. Aside from whether it may be a PITA to load or unload (the Rhino-rack videos make it seem quite straightforward as you use a cordless drill attached to a gear & pulley mechanism to load and unload the boat ), I am still looking for insight/comments on whether the combination of the 50# Rhino-rack and 110# pram would be too much for the 4Runner roof rack... Which brings me back to the original question...
Thanks so much.
Thule cross bars are rated up to 165 lbs. If the Rhino-Rack is compatable with Thule bars, you could replace the factory crossbars with a Thule system. I checked Yakima as well, but their crossbars are only rated for 150 lbs.
4Runna4Rumma
