advice on my lift
tmaxx13
Hi, i have an 02 4runner with king coilovers in the front, and the back is stock, running something like 265/70/17, i want to be able to put 2 sizes bigger or roughly 2.5inch bigger tires, does anyone know how much i can raise the front since its 4wd with out messing anything up, i already have a 1in diff drop, but need to know how high i can lift it in the front before i will get any problems, or what will need to be upgraded to lift it higher, also i want to lift the rear 2in, can i just change out the coil or do i need to do the shock as well? any advice?
lift info
http://www.toyota-4runner.org/3rd-gen-t4rs/66976-3rd-gen-4runner-lift-information-faqs.html
if this does not work you can search
3rd Gen 4Runner Lift Information and FAQ's
might help you out some
Also it really up to you on the rear struts if that is what you are talking about not to much to get and not the hard to replace I would do it all last thing you want to do is take it all apart then have one go out.
And from what I have heard 3.5 is the highest you can go 3inch if you use your shocks with diffrent springs
workingwheelswnc
