Advice on sagging rear when towing
I'm looking around now because I've read a number of accounts where Airbags end up rubbing holes through
4 years with my AirLift bags and no leaks, no problems. A simple, low cost option. I did not remove the springs, just flattened the bags and worked them in between the coils.
There is a good write up from [MENTION=65614]Antman[/MENTION], i used it when I installed mine. It's in the Stickies at the top of the forum page -- Airlift 1000 airbag install by [MENTION=65614]Antman[/MENTION]
I put around 1500lbs in the truck a couple of weeks ago. Was mostly concrete and Portland bags. I had the lightest steering ever! The front end felt like it was barely touching the ground. Rear was down several inchs.
I would suggest whatever they rate this pig at, but it in half and use that number. :drum:
Yikes! Your suspension isn't thrashed or something is it?
