Affordable94 stock muffler replacement?
grenda
As you can see by the photo below I'm way overdue for a new muffler. Yes, I know that's ridiculous. Wanting to save as much as possible on a college student budget I would like to get a muffler off a 2nd get from the junkyard (rust free of course) instead of taking it to a shop.
I would like to cut the pipe just behind the cat and put the new muffler on with some sort of clamp system. Where can I find something like this? Utilizing a clamp and some high temp sealant is my objective. It does not have to be perfect, but it will be a massive improvement from where I am at right now.
Also to change it out the rods that come down from the rear of the muffler and insert into the hard rubber? How to I swap those out? Is there a special tool for this?
Thanks for your help guys!
Grenda-
I looked at Bosal, Walker, factory Toyota, and decided to go with the factory unit. The price difference in WA was not that much (ie $20-30). At least with the factory unit, I knew it would fit, and be a relatively easy install (with a mapp gas torch). You might check, but Toyota might give a lifetime owner warranty on the part as well. No affiliation, just satisfied customer. Best of luck with it.
regards
