Outer cv axle boot leaking grease after oem toyota boot replacement.
Road_Runner
Junior Member
I recently replaced both left and right cv axle boots on my 2009 v8 4wd 4runner. After purchasing it I noticed the boots were ripped. So instead of removing the original cv axles " which were still working no clicks or loose parts" and waiting to get them rebooted I bought a set of gx470 axles "read they were same for gx470 and 4runner" I also bought a set of OEM 4runner boots for both sides. Took them to a local shop had the install the boots. After they were done I had my mechanic install the cv axles along new hubs, brakes, total chaos uca, moog lca and bilsteins with ome springs. Soon after install the outer boots started leaking grease. I noticed the clamps used were not ones I provided. They ended up using the shops own universal fold over not the crimp clamps. I replaced them for crimp clamps but they still leak but not as bad . Another shop that rebuild axles said toyota oem boots have very hard rubber where the clamps meet. He said those oem boots always leak and need a specialized tool asside from the clamp rachet tool to tighten correctly. Any advise?? Should I use screw tight clamps??
Get the Toyota knockoff tool off Amazon. Pinch clamp pliers won’t do the job. I used one of these on my outer boot after I broke the fold over clamp. It’s been fine. These are nice because you can put them on without removing the axle. That plastic they use now for the boots is really firm and requires a lot of force. Don’t use worm clamps.
https://www.amazon.com/gp/aw/d/B07QPRVK76
Thanks for recommending a quality place to buy Toyota replacement parts on Amazon. I really think if Retro Bowl possible, you should choose genuine products to ensure quality and usage time.
Thanks for recommending a quality place to buy Toyota replacement parts on Amazon. I really think if possible, you should choose genuine products to ensure quality and usage time.
It’s not a part that goes on the vehicle. It’s a pinch clamp vise that is like the Toyota SST except for less money. Not a complicated tool. But still far more effective than pinch clamp pliers for getting the boot clamps tight.
Deno91
