After A 3Inch Revtek Lift...
the_josh said:
after i do a 3inch revtek lift, what would be the biggest tires i can fit on a fourth gen sport????
285's and u'll rub. minor trimming required. trimming I believe only requires if you get any kind of M/T tires. If you get A/T tires, you should be fine.
Good Times -
Just to clarify you're saying a standard A/T tire, like the BFG or Revo, in a 285/65/17 should fit with a Revtek or Daystar lift without trimming?
TIA
I Believe you should be fine. Regardless, trimming is very mininal to begin with so you might not notice much.
Please do keep in mind that the rubbing will vary as it all depends on the wheel spec as well. Backspacing and offset does make some difference.
You may get some rubbing at full lock. :)
The trimming won't require you to remove anything significant.
what tire size would it be? if i used 285/??/17
ill wanna keep the stock 17's
i looked and the revo dont come in 285
i could be wrong but i wasnt able to find the size 285/65/17 available in the revo on the bridgestone website...
I am getting LT285/70R17 BFG AT KO. Tires should be in Wed. and I'll let you know if/how much they rub. I am also keeping the stock rims for now. Cas
Please let us know. I am considering to keep my stock rims (save a few pennies) after my lift as well. Please post a sh*t load of pics too. (Yes, I am very visual).
Any idea if 255/80r17's will fit under this lift? Ive read up here the 255's are easier to fit than 285's and Ive also heard its harder... any idea's i feel like it would work but i want some other opinions before i buy any advice is good advice haha thanks
Any up dated on the revtek 3" and largest tire
Im getting a revtek 432 kit, want to put 285 Nitto Ridge Grapplers on a gen 4 Trail, I did a search didnt find much.
I don't really know metric and such but I have a 3 inch bilstein/RC lift and I'm running a 33x12.50. I had to cut and hack my way to daylight to eliminate rubbing though. That's all because my offset on my rims though. Also since I went with a 12.50 I has to get wheel spacers to avoid rubbing my UCA
Sent from my SM-G935V using Tapatalk
charlesz
