Aftermarket Homelink install help?
xjjeepman
Hey all, just purchased this homelink remote
https://www.amazon.com/Gentex-HV5G-HomeLink-Headliner-Wireless/dp/B00UMQ6H2W/ref=asc_df_B00UMQ6H2W/?tag=hyprod-20&linkCode=df0&hvadid=312155954542&hvpos=&hvnetw=g&hvrand=1070370583176291216&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9005255&hvtargid=pla-568714269810&psc=1
for my 17 SR5 that unfortunately did not come with it. Has anyone installed one of these before? Is there any factory wiring up there already that I can tap into? I think I can figure out the 12v ign on source but not sure on the illumination/back-light power source. If anyone has done this any insight would be greatly appreciated!
Should return it and buy the upper console w/ homelink. Without the MTS and Crawl Control, the HomeLink upper console isn't that expensive. Then it looks factory also.
A homelink equipped rear-view mirror might be an easier install. Depending on the connector you have to your current EC mirror.
Its been covered on these forums. You will have to search for the P/N.
Why would a sunroof have anything to do with homelink being wired?
Because its not an option on the base SR5, so I am unsure of if there is a harness plug for the homelink present. I have found the part #, however there appears to be more than one overhead console with the power sunroof switches, and another with the blank. I cannot find the one with the blank.
See attached for differences...
There is a thread with the P/N for the one without sunroof crap.
I found it over a year ago so i know it exists. I used that thread to get the P/N for mine.
You can also use a Toyota online parts website and look at them all that way. Then just order the one you want.
Was this difficult to install? Been searching for a guide or video but coming up empty.
Thanks for the part # - I do appreciate it. But I still am unable to confirm if the wiring is there for a plug/play for a base SR5. Is that what you have??
the wiring and circuit board are in the roof console for all of the switches, the truck only provides power.
buy it and install it. Its literally plug and play.
Sweet, thanks for the info. When is a good day for you to come and install it?
delislerebecca
